Cheap water injection source
#47
Darius:
Yes, I have a Tec 3 installed on my 968 Cabriolet Turbo. The Ecu have two general purpose outputs with a 16 X16 Map vs Rpm vs Duty cycle table. My plan is to purchase the Aquamist 2c system for stand alone Ecu.
#49
I have decided to make carbon fiber mounts for the water rail. The nozzles I am using are not the usual type that screws into the intake manifold, they are threaded on the other side, so they screw into the water rail, which in turn must be fastened to the intake manifold and sealed. This is after trying several stainless and rubber/steel setups that just didnt seem right. The way it is attatched is similar to the fuel rail.
We will see how they turn out, hopefully they will be keepers
