Show your 951 pics here......
#871
Like everyone else mentioned yes, the light output is crud compared to stock. However, my headlight motor/setup was Toast and i was sick of trying to get it back working so i went with this setup. How often do I drive the car at night? Not Much. I would really like to fiberglass the buckets in and go with some Hella's like JPR or 944Fanatic. (FYI, Fanatic looks like your just using a plate, do you have that screwed into the sides of the buckets, whats the light discharge like with that?
#878
Originally Posted by JPR
Hey Derek,
Yes I did and it is the single best mod Ive done to any car Ive had. It works so well its as if it was designed to have this engine all along. Dynoed 353rwhp and 348tq with just headers and the Linsey 3.5" cat back. Just bought some AFR heads and a cam for an add 100hp but I will not get them in before I update the ring and pinion for a taller final drive on the 968 gearbox we are running.
Cheers,
Jpr
Cheers,
Jpr
#879
Originally Posted by MPD47
"Dated" sealed beams can provide a substancial amount of light output. I've played with overwatts in the euro driving lights, "upgraded" Iceshark type kits, HID's in the the GT Racing buckets, HID's in the fog light locations, and Hella 90mm Rally H9's in the GT buckets (i'm sure there were probably a few other itinerations somewhere in there, but I cant recall). It removes a marginal amount of weight, something you will certainly NOT feel a difference from. You'd be better off with an agressive alignment. I'm not speaking out of my ***, I've played with the options and I can honestly say unless you want to spend the big bucks and put hella 90mm HID's in buckets or your bumper, in terms of looks and lighting output sticking with the stock sealed beams is the best route.
http://www.cardomain.com/item/PILNV510W
I would be interested to know if I would just do two per side for the high beam effect? Would the coverage pattern be sufficient and satisfactory?
And if there are any of these lenses from other cars that will fit the 951 bumper (but for a lot less?)
http://www.cardomain.com/shoplist~t~Bumper+Lenses
