What wheels are those? And what size? Im looking for wheels for my 951 but i cant find any. And the ones I like have to be produced which takes around 14 weeks.
Those are likely RH 3.6 Turbo wheels from Germany. They can suggest proper sizes for you. If you want to get wide rims, it is possible too get the following sizes: Front 18" x 9" and Rear 18" x 11". RH should be able to suggest proper offset (ET). You could also reduce width by 0.5" to make sure you have enough clearance.
I love the look of the 3.6 or 993 RS wheels, but if the RH wheels are anything like the Speedlines... they make better boat anchors as they are quite heavy So, I went with forged 2-piece BBS RS-GTs on my A4 (19x8.5), S2 and 951 (18x8; 18x10).
@Quickbeam more details about those wheels, such as diameter, offset and brand. Looking good and nice scenery!
@sm Thanks. The wheels are Starke SC18s that I got from Tire Rack. Sizes are 18x8.5 et 48 and 18x10 et 45. Since my car is an early offset I run 19 mm spacers up front and 15 mm in the rear.
