AEM EMS in a 944/951/952
#77
PM sent Thom.
#78
Formula One Spin Doctor
I run full sequential (fuel + spark) with my Vi-PEC, stock crank trigger + a cam angle sensor.
I have compared both Vi-PEC/Link softwares and they look 99% identical.
Not sure I understand the benefits of running a 60-2 tooth trigger, as the stock 132 tooth trigger set up should offer better resolution...?
Not sure they went this direction to increase performance but rather to reduce scale manufacturing costs within their partnership with Bosch who were certainly beginning to make set ups for other cars also using a 60-2 tooth trigger.
They introduced the 60-2 set up with the 944S in '87 yet they didn't convert the 8V cars to it.
#79
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
See above…plus I have no wish to reuse old sensors in mission critical areas. The only old sensors that I ever reuse and coolant temp sensors – and if it’s a race engine I replace those too. I also want the ability to set the trigger up the way I want to – set the lead time of the home signal (missing tooth on a 60-2 system or a cam position sensor). The position of the home signal is dependent on the max ignition advance you want to use. Some systems are locked into a specific lead timing, some are not. Another reason for preferring not to use the stock trigger is accessibility. There is a definite benefit to having quick and easy access to any vital sensor on a track car. You never know when you may have to change something!
I am sure people can get het stock trigger system to work, and maybe even work well – I just don’t think its optimal and I am not into compromises when it comes to management systems – if you want to install and set one up then do it the best way possible.
#80
Pretty much what I've found. Seems as if Electromotive, Wolf, Motec, and also LINK have discovered this.
Many are in fact offering a front wheel kit for this reason. This is why I am interested in Thom's experiences?
#81
My experience with adjusting the base timing on my set up with a timing light is that it did not move one bit, and that was with watching the OT mark for a good 10 minutes to check how stable the system was (serious headache following...!). This tells me the CAS used on my set up is precise enough for this application.
As for tooth squareness :
a/ I'm not convinced that the starter ring gear is any less square than the tooth on a S/S2/968 flywheel - did a clutch job a 944S last weekend and the tooth on the flywheel didn't seem particulary "more square" than those on the ring gear.
b/ How could "tooth squareness" matter when used only for a reference sensor dedicated to measure engine speed only? Can the version of the factory Bosch ECU used with the 60-2 set-up (16V engines) compensate for the varying distance between the position sensor and the tooth during the arch of circle of the period of the tooth? I doubt it since the same position sensor is used on both 132 and 60-2 set ups.
c/ If the ECU cannot compensate for the varying distance between the sensor and the tooth, which will be varying greater the wider the tooth, the maths just say that for 132 counts for a revolution the sensor is triggered more than twice than with a 60-2 set up, hence better resolution at measuring engine speed.
#82
On good systems, reference sensor is only used for determining TDC position and engine speed is calculated by teeth. Cam sensor indicates which TDC (1st or 4th cylinder) it is.
#83
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
All that being said – the 944 starter ring gear does have a profile that is ‘squarer’ than most.
As for the compensation for varying distance – its not an issue since the signal voltage generated by the small change is distance is minimal – it is also important to note that the signal delta will be opposite to the rising leading edge. Most good stand alones allow you to choose between a rising or falling trigger. If you chose the rising signal then the slight falling due to the increase in gap distance during the tooth passage is truly irrelevant. I will give you credit for a good try on that point!
In truth the stock ring gear should do an acceptable job in creating a signal for an ECU. My main objection to it is the idea that you can set up your new ECU using the old stock sensors. If you replace the stock sensor with new ones and make up your own wiring harness from the new sensors to your new ECU that will greatly reduce my objection to the implementation of a stock type set up. I still find the position of the sensors and the gap adjustability a maintenance annoyance! I still have a concern about the use of the trigger signal. Some of the systems that I have looked into that have the ability to use the stock trigger system do not calculate the engine speed at the passing of every tooth. Some just use a software based system that calculates the engine speed once a revolution. So you have more trigger events but a lot less final resolution due to the software algorithm.
#84
Thanks for the clarification.
It goes without saying that installing a modern ECU/wiring harness without all new sensors (OEM or not) makes little sense.
Yes, the factory location of the crank sensor is not the most convenient, but to be honest it should not need to be adjusted every other day and it still probably requires less work than installing a replacement sensor elsewhere.
#85
Looks like a little basic info is in order - a magnetic (regular or Hall Effect) sensor does not count ‘teeth’, it measures the ‘change of state’ of the trigger wheel. An electrical charge is created when the leading edge of the tooth passes by the sensor and another charge is created when the trailing edge passes the sensor. The amplitude of the signal is based on proximity. If the trigger tooth has any ‘ramp’ to it (less than completely square) it will create a signal with some analog function and the ECU will have to ‘guess’ at what voltage level represents the actual triggering event. Starter gears tend to have less that square teeth – they need to in order to mesh with the starter without causing undue wear.
Not a problem……even with the auto tensioner in place!
#86
This is what Ray Hall from Vi-PEC has to say about the triggering :
I suppose this means that the ring gear on our cars performs well enough when used with an ECU that can count each of the 132 teeth of the ring gear, such as the Vi-PEC.
I don't have any experience with the Link ECU but if it's as similar to the Vi-PEC as the user interface suggests, I suppose the Link will perform just as well.
From that point I'm not sure how a 60-2 set up could offer as much resolution, unless perhaps if using some compensating algorithm.
Originally Posted by Ray Hall
The [Vi-PEC] ECU does not use RPM. It reads every tooth. The time between the current tooth and the previous tooth is used to calculate when the next tooth should occur. It then looks to see if any ignition or injector events that need to be processed before the next tooth, and deals with them. This gives very accurate ignition and injector timing.
#87
#88
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
My main objection still stands – old sensors and wiring are not a good starting point for a good management system and the original set up is not easy to work on if track side tweaks or repairs are needed.
#90
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
