wastegate group buy?
#31
Originally posted by 944 Fanatic
You'll find that its a shame to mount something as cool looking as the TiAl out of sight under the car.
#32
If your 100% call Tim at speed force racing.
Their number is on their website, under contact us.
Unless you want to give me your billing information, credit card number, bank account numbers, and oh I'm going to need your pin number as well..............
let me know how many have purchased theirs so I can keep count!
#39
The group buy is definitely still going, in fact it has just started!
It's a tial 38 mm wastegate,
the adapter so it will bolt right up,
all the hardware to install it,
you specify the spring rate.
All for $290.
from what I understand that is $15 cheaper than the last group buy!
contact Tim at Speed Force Racing.
Good Luck,
Eric
All for $290.
Good Luck,
Eric
#43
Id' be interested in either one....Is there a big gain in going from a 38 to 46mm unit? Does someone have a number of where we're getting the items from?
#44
What spring rate would you guys suggest. Right now, I have a stock turbo, Huntley MAF kit w/ARCII, Adjustable boost and fuel pressure regulator. I plan on adding the 55# injectors and eventually will get a bigger turbo.
#45
badass951, I think you're confused on the wastegate purpose, larger is not always better, especially on smaller engines like ours. You won't notice a single performance difference between the 2.
Sam
Sam
