Let me guess, must be a GT30 series
turbo. Chris, are you using wet sleeve or dry sleeve set up ? Thanks |
Originally posted by J Chen Let me guess, must be a GT30 series turbo. Chris, are you using wet sleeve or dry sleeve set up ? Thanks As Hertz would say "not exactly". It's a Garrett turbo, it's expensive, it's also very effcient. The motor is wet sleeved with an oring in the top of the sleeve with a receiving groove in the head. |
Very impressive. At what rpm was your peak torque?
About 5600 rpm.
If not GT series I suppose it's the T-series. Would be extremely interesting to know the full specs but understand if you want to keep them secret!
Tried any VATN turbos???
Is this the turbo for which you made that slick little adapter plate to mount?
YES.
Chris, what kind of money to set up a block like that. Somewhere in the 5K range?
__________________ Best Car Insurance | Auto Protection Today | FREE Trade-In Quote |
Hi Chris,
Do you sell the sleeve & pistons ? Regarding sleeves, are you using Dartons integrated Deck sleeves ? Thanks |
April Fools?
Originally posted by NZ951 April Fools? Matt, somewhere in the 4-5k range. JChen, I will check. I don't recall off the top of my head. |
Originally posted by Duke If not GT series I suppose it's the T-series. Would be extremely interesting to know the full specs but understand if you want to keep them secret! Maybe I'm totally off base here, but it's pretty annoying. It seems like just bragging rights to me if you don't want anyone to know how you did it. |
Originally posted by Silverbullet951 I still dont get why anyone would want to keep it secret. Doesn't make any sense to me. If you got something good, why not share it? Maybe I'm totally off base here, but it's pretty annoying. It seems like just bragging rights to me if you don't want anyone to know how you did it. |
It would be kept a secret because we:
a) found and purchased the turbo's = time and money b) spent a lot of time and money making them fit a 951 as simply as possible. c) spent a lot of time and money tuning and developing drop in chips and fuel, timing and boost maps for Motec. d) see David's reply |
