Track car pics
Old 05-22-2004, 01:09 PM
  #151
SamGrant951
SamGrant951's Avatar
ski- What kind of price are you looking for on the Lemans spoiler? pm if you dont want to list it here...tia
Old 05-22-2004, 02:37 PM
  #152
Duke
Duke's Avatar
Originally posted by Ski
Looks great!
Probably just a test fitment but the tyres looks like they're mounted in the wrong direction?
Old 05-23-2004, 10:30 PM
  #153
Ski
Ski's Avatar
Pictures are more fun to look at
http://gallery.rennlist.com/gallery/JABRacing
Old 05-24-2004, 09:22 PM
  #154
Ski
Ski's Avatar
Now getting to the nitty and the gritty.....Jim and Gary got itchy today.
either the o-ring or the little clear plastic was leaking here
great walls at 91k
glad we had the extra head done ahead of time
Old 05-25-2004, 10:15 AM
  #155
DAR951
DAR951's Avatar
That's right... concentrate on posting (and working on) your own car....
Cylinders (what we can see of them) look as good as the head and front seals look ugly! Nice move on the new LR head.
Old 05-25-2004, 10:41 AM
  #156
Ski
Ski's Avatar
Thanks Don. You wouldn't have a copy of the updated vacuum drawing anywhere would you? Did you delete the IAS too? If you do could you email it to me at blpski@yahoo.com ...or anyone who has it in jpeg form TIA!
We hope to have it fired up Monday, June 7th for the first test drive; we'll see. Jim is going to try to have the crossover pipe off and the old turbo out by the time I get there so that should speed things up on that weekend of the 4,5, and 6th.
Old 05-25-2004, 09:47 PM
  #157
Ski
Ski's Avatar
more boxes opened
KLA brace - thanks Scott
LR Stage III MAF
Mafterburner setup
from www.egauges.com
Old 05-25-2004, 10:20 PM
  #158
Silverbullet951
Silverbullet951's Avatar
I wish I could be doing this to my car....
Old 05-27-2004, 03:34 AM
  #159
Geo
Geo's Avatar
Originally posted by turbite
Howd you guys get that interior so clean?
You just use a heat gun to get all the gook off then spray paint it?
I used the heat gun method, followed with LOTS of rubbing with 3M adhesive remover.
This isn't the best pic I have, but it's the best I could find quickly.
Old 05-27-2004, 06:51 PM
  #160
WolleMS
WolleMS's Avatar
real good cleaning work... how long does it took ?
Old 05-27-2004, 07:10 PM
  #161
Transaxle
Transaxle's Avatar
Some impressions from the brutal path...
1. Car
2. Cage
3. Acid bath
4. New Look
All pictures here...
Old 05-27-2004, 07:23 PM
  #162
Geo
Geo's Avatar
Oh my...
I have no idea. It took quite a while. Using the heat gun left lots of thick adhesive residue. I wouldn't think 30-40 hours would be out of the question. But, I'm pretty particular about that. I went back more than once to an area I already declared to be done to get it a little better. The problem is, once you paint it, going back and getting the gunk off is pretty much out of the question.
Here's a photo of what I started with:
Obviously the spot on the left floor is post cleaning.
Old 05-27-2004, 07:36 PM
  #163
Geo
Geo's Avatar
Tom, cool pix!
As long as we're sharing, here are some pix of my cage. I have now installed the dash bar (which will run through the dash itself) and the passenger door X. I just have to have a few welds completed (I only tack - I weld like a monkey with one hand and three tails), add a few misc brackets, and finished the mounting plates.
If I were to do it over, I might consider moving bar that is the upper front part of the X lower and tying from it where it attached to the front down tube to the firewall and gussett between it and about 6" above the down tube bend. But, my dash bar ties in right where the top of the X is, so it's pretty solid.
Old 05-28-2004, 04:29 AM
  #164
Skip
Skip's Avatar
I like that lower bar setup. I'd like to have one a bit lower myself. However, where will the shoulder harnesses mount to?
It looks like most of these cages are not going too far back in the car. Here's mine showing the rear most bars going way back to the side pockets:
Also, our door bars look very similar, but yours are so much closer to the chassis! Nice detail! Here's mine before painting:
I think if I build another one, I'd go for the full door intrusion NASCAR bar setup to give myself some more crush zone and make entry/exit easier. The diagonal door bar is almost too close to my elbow when driving... it's "acceptable".
Great looking projects in here!
Old 05-28-2004, 11:55 AM
  #165
Geo
Geo's Avatar
What we've done is tied the cage to the suspension mounting points. On ours we have the main hoop braces tied to the rear shock towers.
Quick Reply: Track car pics
