Fuel Pressure Gauge mount on Aftermarket FPR
Hey Rennlisters-has anyone mounted their Fuel Pressure Gauge directly to an aftermarket Fuel Pressure Regulator? Mine is an Aeromotive FPR running to a CEP Fuel Rail. I want to mount the Gauge to the Regulator pointing straight up so I can look at it while adjusting. Hoping someone has the magic list of fitting part numbers for a clean look.
Thanks in advance!!
Thanks in advance!!
Just a thought here... how about having a port available for it that you can connect to when you need to see the fuel pressure or adjust it? My guess is the gauge itself really doesn’t add a lot of daily value. The closer you mount that gauge to the headers, the more likely the heat will affect it and those mechanical gauges are not the last word in “high quality manufacturing”.
Bonus points for style by getting one more thing out of the engine compartment!
I have the same CEP rail and used an Aeromotive AFPR. The gauge should mount onto the the front on the regulator without an adapter, just a but Teflon tape. Adjust with vacuum line off regulator, set to 43.5psi / 3bar, tighten and that should do it.
I set mine up with the dampener on the front of the fuel rail and a Marshall anti vibration fuel pressure gauge mounted off the dampener. I have a photo of my setup in my posted photos but I can’t seem to download a photo of it now.
