OPRV alignmant tool dimensions
I'm into the dreaded OPRV/oil cooler seal drama on my '86 951, but don't yet know if the OPRV has been upgraded or is the original early version.
The alignment tool is unavailable, or extremely expensive.
Question for anyone with an OPRV alignment tool suitable for the '86 car: What are the dimensions of the tool, and how far from the tip is the shoulder where the shaft enlarges? I plan to make on with a wood dowel rod.
$23 is expensive??? Try the timing belt tension tool!
https://www.pelicanparts.com/More_Info/PEL-TOL-P218.htm
What extra complications to the turbo cars have with OPRV replacement due to our oil cooler hoses to the lower oil radiator, i.e., how much do the oil cooler hoses get in the way when fixing the OPRV?
Some YouTube videos show first removing the exhaust manifold, then working the OPRV from above on a NA car, but on an early-version turbo car, what's best? Seems to me, removing the exhaust manifold puts the studs at risk or damage, making lots of extra work, so it would be best to leave the turbo ex. manifold alone, and work from below the car. Others knowledgeable please chime in.
