Fun with speed and reference sensors
I've been gearing up for a new project and thought I'd share a bit. I may have misspoke in the video about the 200rpm test-spec, since I was looking at the speed sensor at the time, but thought this video may be of interest regardless to show how the sensor gap changes the output...
Cool test, Tom! Did you spin the flywheel by hand, or is there some sort of motor under there?
The next questions that come to mind: Is there any difference with the bell housing in place? What happens when the sensor bracket / bell housing are grounded?
BTW, any luck with those early DME boards? Did you figure out the ref/speed sensor circuits on those?
--Jay
--Jay
--Jay
--Jay
No motor, I use a drill with bristle brush to get the flywheel spinning. It works, what can I say... I 3d printed a hub to mount the flywheel on, which sat over a bearing, but eventually I had the hub made in aluminum by a friend. You can see in the video that even the slightest run-out causes the signal to get stronger and weaker, so the plastic had to give way to metal...
Very interesting indeed. FYI through my trials with the FAE brand sensors, I discovered that those are ever slightly different size: I set the gap using one of the FAE brand + .8mm washer and then installed a Bosch sensor in its place, noting a distinct drop in signal level. The difference is so slight that someone using aftermarket sensors wouldn't notice by eye but it could affect signal
Tom, cool video. Thanks for sharing. Where's this all headed?
