I purchased a 944 Turbo!
Old 12-23-2018, 12:06 AM
Cm09578
Cm09578's Avatar
Default I purchased a 944 Turbo!
Hello all, I purchased an 86 944 Turbo with 46,xxx miles in excellent condition. Garage kept its entire life in Arizona.Timing belt is new (900 miles on it) and changed. The only issue with the car is it has not been started in 4 years. Other than new battery, new tires, new plugs, draining all fluids and maybe hand cranking for the first start.....should I look out for anything else? Thanks!
Old 12-23-2018, 01:18 AM
Humboldtgrin
Humboldtgrin's Avatar
Very cool! The first thing you absolutely need to do is change out your fuel lines to and from the fuel rail. After that have fun being a 951 owner.
Old 12-23-2018, 08:53 AM
EVOMMM
EVOMMM's Avatar
Received 1,549 Likes on 913 Posts
Also pull the spark plugs shoot some marvel mystery oil wait overnight and some gas additives and have a merry Christmas
Old 12-23-2018, 09:04 AM
MAGK944
MAGK944's Avatar
Congrats! ....but pictures please, we like pictures
Old 12-23-2018, 10:17 AM
jerome951
jerome951's Avatar
Congrats on the purchase. Sounds like a really nice car.
How many years on the timing belt? They age not just from mileage.
I'd suggest pulling the coil plug from the distributor cap on your first cranks to build oil pressure first, reconnect and you should be good to go. My car often sits 6 months at a time between starts and it fires right up without issue.
Good chance you'll have a noisy lifter or 2. Let the car idle for a while and it should go away.
Old 12-23-2018, 10:00 PM
Cm09578
Cm09578's Avatar
Thank you, where can I purchase or do you have a part #?
Old 12-23-2018, 10:01 PM
Cm09578
Cm09578's Avatar
Thank you! Merry Christmas to you!
Old 12-23-2018, 10:03 PM
Cm09578
Cm09578's Avatar
here you go!
Old 12-24-2018, 09:17 AM
EVOMMM
EVOMMM's Avatar
Congratulations !!!!nice ride
Old 12-24-2018, 09:25 AM
MAGK944
MAGK944's Avatar
Nice! I admire white 951’s even though I’ve never had one.
You should be good with a change of all oils and gas then hand crank a few times. Remove the belt covers and check the belts for any deterioration like cracking from sitting in one position for so long. As others have said the three fuel lines connected to the fuel rail if they haven’t been changed.
Old 12-24-2018, 09:46 AM
michaelo
michaelo's Avatar
Very nice looking Porsche. Let's see some interior pics.
Old 12-24-2018, 10:29 AM
SamGrant951
SamGrant951's Avatar
Looks clean, congrats!
Old 12-24-2018, 11:01 AM
Humboldtgrin
Contact Lart here on rennlist for the fuel lines. Or pay 10% more thru eBay to him for the same stuff. He might even have a Christmas special?
https://rover.ebay.com/rover/0/0/0?m...2F254001937632
Old 12-24-2018, 06:09 PM
Cm09578
Cm09578's Avatar
Thank you!
Old 12-24-2018, 09:30 PM
Cm09578
Cm09578's Avatar
Finally made the trip home from Arizona to Delaware! Merry Christmas to all!
Quick Reply: I purchased a 944 Turbo!
