First car -> Am I way in over my head?
I've always been a big fan of the Porsche 944 and I want to purchase one for my senior year. A local seller was selling a 1983 944 with the description as:
1983 Porsche 944 in Guards Red. Car is running and driving but NOT WELL. The rod bearing is going bad in the engine so it will need a rebuild to run perfectly. Prior to this, the car ran well. Car is great for parts or repair. Will likely run about 20-25 miles safely before the engine causes serious concern. Car does pass smog, and does have a timing belt change within the last two years. Has a new brake booster and master cylinder. 5 Speed manual, clutch is in good condition.
In terms of fixing this car, as a high schooler with no access to any professional lift system, is this even possible?
Professional Hoon
If you love the 944, spend the money on one with lower K's on it and or looked after well.
FYI this is the turbo section.
You'll have more response to the N/A models here.
http://forums.rennlist.com/rennforum...-968-forum-70/
If you believe that statement, you're in over your head.
And as others have said, find a cleaner running car and enjoy it.
They all need some amount of TLC and work done to them to keep them on the road. We've all been there.
I've owned mine for 20 years....had a 924S prior to that so essentially have had one my entire working life. I was thinking about getting one for my daughter when she turned 16....They are "cheap" and I can pretty much fix anything on them. Be we gave her wife's BMW 328i. Main reason.....better safety features. Modern cars are just built much safer. These are fun cars but at 30+ years of age....wires, computers, etc can and will give you headaches.
Not to go Dad mode on you but your in high school.....focus on college, career, business, whatever you want to pursue so you can buy a new 911 or Cayman in the future.
Can't make money if you can't get to work because a Speed Sensor failed.
But to answer your question....In terms of fixing this car, as a high schooler with no access to any professional lift system, is this even possible? Yes...(assuming you have money for parts...and time to learn)
Don't buy it! A shop will charge more than the car is worth to change the rod bearings. If you try to fix it yourself, by the time it's back together, you will likely be contemplating retirement after a long and successful career at the Flying Car Company.
First of all, certainly run away (quickly) from the car you're considering. Picking it up for free would be paying too much.
There are decent cars out there where the seller has taken reasonable care of it. Doesn't sound like the case with this car.
That said, these cars are a lot of work and new parts can be reasonably expensive. I've also had my car for 20 years. The first several I was certainly in over my head, but with a lot of time and $$ (and a lot of help from this and previous forums) I've now got my nose above the waterline. Then again, I've spent $$$ on tools, professional shop repairs, and spares that didn't solve a problem, to get to this point.
If you're in the DC area, come and help me replace speed/reference sensors and the associated wiring harness to the DME after the Christmas holiday. If you can manage that task without giving up, you may just be all-right. I'll provide free encouragement and coaching. ;-)
