New struts question
Old 12-01-2018, 07:38 PM
No.15
No.15's Avatar
Default New struts question
Hi
Pretty new to Porsche so forgive the novice questions.
I have a NTM 1987 944 turbo that I plan on using for autocross/track use.
Suspension is in rough shape and I want to replace the struts and the shocks in the rear. Right now I have the basic stock setup, but per rules I can use any option that was available on the car at the time.
So can someone tell me what I should be looking for so I can have the best setup allowed? I imagine I will have to search used, but if available new I could go that route.
Old 12-01-2018, 10:30 PM
968to986
968to986's Avatar
I recently upgraded my 87 turbo with new Konis front and rear. Changing out the rears is pretty straightforward, but the front struts are a sealed design. You have to cut open the strut and remove the internals to put in the Koni insert. Paragon is an excellent source for the Konis and the DIY instructions. While I was at it, I added their front coilover conversion with 250# Hypercoil springs and rear 28mm torsion bars. Even with the stock sway bars, the car is totally transformed. My car is street/track setup, so a bit of compromise on both sides.
Old 12-03-2018, 12:13 PM
No.15
No.15's Avatar
Thanks for the reply. Would it make sense to source used struts off a car with the upgraded struts? What is the generally accepted strut life as far as milage goes. If I do m30 (?) Struts do I have to upgrade the spindles?
Old 12-03-2018, 01:56 PM
Jason @ Paragon Products
Jason @ Paragon Products's Avatar
Rebuilding your struts with the Koni inserts is probably the best thing to consider. The chance of finding some original struts that are still good is probably not great. M030 stuff will bolt on your car without modification but you need the springs and perches as those are particular to the M030 cars.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 03-21-2020, 03:18 PM
Radmd74
Radmd74's Avatar
** Which aftermrket front (and rear if available) strut bar is best for the 944 Turbo (87 model here)? No engine bay modifications are present.
Old 03-22-2020, 04:31 PM
3 possibilities John:
KLA
https://www.paragon-products.com/KLA.../kla_944sb.htm
Racing Dynamics
https://www.paragon-products.com/Rac....99.00.011.htm
Brey Krause
https://www.paragon-products.com/Bre...p/bk_r1522.htm
Quick Reply: New struts question
