power steering return line
I need to replace my return line (the one with the cooler. It looks like its 2 pieces joined between the cooler and the rack. Does anyone know what the actual fitting to hold the 2 pieces together is? just a hose clamp? im talking about what hold 8 and 9 in this diagram together
https://cimg9.ibsrv.net/gimg/rennlis...2f4599b678.png |
https://rennlist.com/forums/944-turb...ine-bay-2.html
Unless it's damaged as in the metal is crushed it can be repaired with the new ends as seen in my thread post number 20. Where are you located? If you can't find a source locally I can have it fixed in Calgary for you at Greenline hose and fittings. The repair prices are probably still the same...and that is in Canadian dollar at about 77 cents on the US dollar...great for you....sucks for me :) And yes it is just a hose clamp. |
https://cimg9.ibsrv.net/gimg/rennlis...201375c880.jpg
I just cleaned the steering rack from one of the cars yesterday and installed the rack and engine cross brace and can 100% verify this as I have 2 of each of these hoses sitting in the garage right now.....nice and shinny clean. |
Originally Posted by gruhsy
(Post 15379769)
Yes held together with a hose clamp for sure.
The fitting on the left is a flare type nut that threads on to the longer hose end of the cooler pipe. It's nice because you can disconnect it at that location also. Greenline put on an imperial size hoses that are almost identical in ID to the metric lines. I would have to stop by Greenline and ask the name of the fittings as this was a few years ago now. |
The low return line is low pressure, almost anything will work. Do you have that thing running yet?
Originally Posted by rlm328
(Post 15393255)
