734 rwp @ 1.6 bar. 3.1l 16v turbo
Old 09-12-2018, 11:12 AM
URG8RB8
URG8RB8's Avatar
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
Amazing results Gustaf, all that hard work paying off!
Old 09-12-2018, 04:52 PM
Jon951
Jon951's Avatar
Congrats! Incredible results from incredible engineering!
Old 09-12-2018, 07:48 PM
333pg333
333pg333's Avatar
Originally Posted by Duke
Hi Patrick, in the end we were so pleased with the torque curve that we didn't feel we could gain much by playing around with the cams from the current setting.
The new engine will likely make power to 8000-8500 rpm so it should gain some nice power just by allowing the engine to breath higher up.
But we're close to the limit of the EFR9180. It's really not a 1000 hp turbo for big displacement engines.
But I'm chasing cooling issues that have followed the car since several years. I'm now leaning towards stock water pump cavitating with the setup in the car.
Looking at pics from your Meziere installation! Likely to go that route during winter.
Yeah that tq curve is very nice and usable. Especially on your tracks I'd imagine. Gearing may effect where how high you need to go in rpms in terms of staying in a certain cog on a certain location on any track...but with the SQ box it's possibly not as crucial. I would definitely look into an aftermarket waterpump as we've discussed. Sorry I can't get you the model number of mine. I just can't seem to find a receipt or even pic showing part#. It does have the highest flow rate though. As you probably know, Rod switched to an electric pump a while back.
Old 09-12-2018, 10:10 PM
Noahs944
Noahs944's Avatar
Duke,
curious if you still run balance shafts?
-what balancing did you do to your engine?
Thanks,
Noah
Old 09-13-2018, 04:24 AM
Voith
Voith's Avatar
That is impressive stuff! Congrats. Post some 1st person videos please, that has to be wild.
Old 09-13-2018, 04:28 PM
Jay Wellwood
Jay Wellwood's Avatar
Originally Posted by 333pg333
<big snip> Rod switched to an electric pump a while back.
This caught my eye, did a brief search and came back with minimal hits on an electric water pump swap from both benefit and experience perspectives.
Duke - are you running the same kind of setup?
Old 09-14-2018, 03:59 PM
Laust Pedersen
Laust Pedersen's Avatar
Very impressive indeed.
How is the transmission holding up? And has it been strengthened to take the extra load?
With respect to electric water pumps (EWP) I do have references and positive experience, although they are most beneficial for street cars in traffic.
Here are references to 4 different EWP manufactures, some of which also sells controllers:
https://www.meziere.com/Products/Coo...tor-Mount.aspx
http://www.tecomotive.com/en/tinycwa-en
http://www.kspg.com/fileadmin/media/...lmittelp_e.pdf
http://daviescraig.com
http://www.stewartcomponents.com/ind...tegory&path=63
I originally had a Davies Craig EWP-80 on my Jalpa TT, but it had inadequate flow. So since I was installing turbochargers, I got creative and designed a hybrid water pump based on a turbo compressor and a Davies Craig EWP motor as shown below. The simple philosophy behind the effort was, that turbochargers have much better engineered fluid handling capacity and from fluid dynamic standpoint air and water are not that different (except for compressibility and density, which is compensated for with impeller speed). The result is a measured doubling of the flow.
It has worked great since 2014.
Laust
Old 09-15-2018, 10:38 AM
Jay Wellwood
Sorry for the hijack Duke.
Thanks for the info Laust.
Old 09-16-2018, 03:32 PM
cruise98
cruise98's Avatar
That is impressive. I bet it is an adrenaline rush from 3000 to 4750. Do you even have time to blink?
Old 09-18-2018, 02:51 PM
gruhsy
gruhsy's Avatar
Awesome. Thanks for sharing.
Old 09-30-2018, 10:05 PM
EliteThink
EliteThink's Avatar
wow, incredible power, nice job!!
Old 10-01-2018, 04:03 AM
Duke
Duke's Avatar
Originally Posted by Noahs944
Duke,
Thanks,
Noah
No balance shafts. Crank, flywheel and pullies are balanced together.
944 timbo (11-28-2022)
Old 10-01-2018, 04:06 AM
Duke
Duke's Avatar
Laust
Thanks for the info.
I'm not sure yet what needs to be improved with the cooling. If it is hot spots or cavitation. Got an answer from Meizere and apparantly basically all mechanical pumps flow more than the electrical ones at higher rpms so I suspect flow is not the issue here.
The transmission is a Kaps Transmission 6 speed sequential transaxle. It is rated to 1000 Nm.
Old 10-01-2018, 11:54 AM
gruhsy
gruhsy's Avatar
Who is the manufacturer of the sleeves in you engine?
Old 10-01-2018, 11:55 AM
Duke
Duke's Avatar
Darton MID.
Quick Reply: 734 rwp @ 1.6 bar. 3.1l 16v turbo
