Heater Control Valve
Guys - no heat or cold working because it was confirmed that the HCV was stuck open - no vacuum. The problem is that we cannot find a leak anywhere in the system. Is there any common things to look for, or actually, uncommon things to look for, that we might not be thinking of? This is at my Indy's shop, I have not had time to tackle myself, but he is frustrated. Thanks for any help!
In the factory manual, starting on 87-61, there is a troubleshooting guide, which for your issue seems to focus on the three interior temp sensors inside the under-dash hvac unit (which you can test via an accessible plug), and on the control solenoids that regulate the vacuum lines. I don't see mention of the HVAC control box in the dash, but that part is known to go bad too so I'd put it on the list. If you don't have access to the manual, I'm sure one of use could post the relevant pages...
http://www.uriarte.dk/porsche944/garage/workshop.html free download of factory manuals. Have fun. Heater system should be under section 87. How about that just like the modern Porsche Audi VW setup still.
Check and see if you can verify that the heater valve is closing. I had one that still leaked enough hot water to have heat in the cabin even though the valve appeared to be shut. Replaced valve with the metal Audi 5000 part, put a ziptie on the vacuum line and it was fixed.
Thanks for the tip though and the Audi reference.
OK if you end up replacing the control unit, look for a later one as they improved them over time. Until you get to 968 they all seem otherwise the same, the 968 has a detent pot for the temperature.
Maybe also try checking to see if vacuum to the heater valve will close it, maybe the valve diaphragm is leaking.
The heater control valve definitely holds vacuum under test.
I'm going to do the sensor test as mentioned by Tom that resides on 87-61 but haven't yet determined what the manual means by "Remove control switch and pull plug A."
Anyone know?
Anyone know?
