Can I NA my Turbo?
Can I NA my Turbo?
I've run a 1987 944 Turbo as a street legal track car for the last 11 years. It's been good to me and I've got it setup to be a perfect dance partner. I've kept up on engine maintenance over the years, rod bearings, head gasket, fresh head and turbo etc. A driver side balance shaft leak and a few others have been getting steadily worse, so I really need to pull the engine and address it. While the engine is out, I'm wondering can I NA it to simplify things?
Some details on my car ->
Front Suspension:
400in/lbs springs
Racers Edge Camber Plates / High Strung 44 Control Arms with monoball bushings
Ground Control coil over / Koni Sport
30mm front sway bar
Rear Suspension:
650in/lbs springs
Elephant Racing Poly Bronze Bearings / Solid torsion carrier mounts and monoball bushings
Ground Control coil over / 30 series Koni
19mm adjustable rear sway bar
Weights:
Corner balance:
818.....810
782.....747
Cross weight 50.4%
Total weight 3157 including half tank of gas and 215 for driver (2942 without driver)
Brakes:
Front:
996 GT3 4-Piston calipers on 330 Cayenne rotors
Pagid Orange pads
944 Turbo Cup cooling ducts and 968 air spats
Rear:
Stock 944 Turbo calipers and rotors
Pagid Black pads
Safety/Interior:
Heigo bolt-in rollbar
Cobra Evolution GT halo seat
Scroth harnesses
Momo Mod 07 wheel on NRG quick release
Transmission:
Stock 944 Turbo with added Quaife TBD
Steering:
Factory manual steering rack
Wheels:
993 narrow body fitment Hollow Spokes - 8" front 10" rear (no spacers)
Front Suspension:
400in/lbs springs
30mm front sway bar
Rear Suspension:
650in/lbs springs
Weights:
Corner balance:
818.....810
782.....747
Cross weight 50.4%
Brakes:
Front:
Pagid Orange pads
Rear:
Pagid Black pads
Safety/Interior:
Scroth harnesses
Transmission:
Steering:
Wheels:
fasteddie313 (07-29-2019)
Rainman
what else are you planning to do?
addressing all oil leaks, new clutch, etc can be done over a weekend and you'll be driving in boost again by monday.
putting another engine in that youll just take out later adds lots of complication?
and even running the 8:1 block non boosted would still give you in the 130hp range.
Need to line things up just right, don't want to dent those long tubes or crack that new radiator...
