Moved to Cali! Question about 1986 944 Turbo
I've moved to San Francisco CA from the southeast, and am thinking about registering my 1986 944 Turbo with ~40K miles in the state of CA.
Background:
-- The car is going to be based in CA and parked in my garage...
-- I have a house that I am keeping in Nashville TN so have an address there etc etc.
-- Car is 100% stock condition, no alterations to engine or emissions
-- This will be a weekend driver at best... (3rd car)
-- The car is currently registered with TN Antique Tags (permanent registration ie no annual renewal, no emissions testing or annual hassle)
Looking for guidance. Do I:
1) Register in CA, emissions test -- will it pass? (I have read a range of thoughts online from "You will have no problem" to "don't even try"...)
2) Keep it registered in TN with the Antique Tag, change garage location with insurance (they will be OK with this, have done it before), and don't worry about it.
Side note: The emissions sticker looks like this, it doesn't say CA specifically. Is this a 50 state car or 49 state ?
FWIW, I have one other car that will remain registered in TN because it's garaged there. I have a newish SUV that is in CA that I guess I'll be registering here. So will have vehicles registered in both TN and CA, with residences in both as well.
Keep it registered in TN to save yourself the hassle with CA smog laws. If you have not had it smog tested in a number of years, there is ~75% chance you will fail CA smog due to California's tighter emissions requirements. Typically, current CA emissions standards are tighter now, then when your car was new. If you fail CA smog once as a gross polluter, you will be required to smog test your car annually going forward.
You have to test anualy in San Francisco anyways. By law you have 10 or 14 days to register your car in California if you plan on keeping it in California. But there isn’t a law that can’t be broken except the laws of physics and those are only guesses.
Rainman
If your car is 100% stock, and everything is still up to snuff (no vac leaks), your car will have no problem passing California smog.
49 or 50 state doesn't matter for a used car.
You could probably get away with leaving it registered in TN on TN plates, but CA actually has a "tip line" for people to report cars to the state that might be cheating emissions or registration requirements...seriously.
Have to ask though...WHY would you ever leave Nashville for a ****-hole like SF?
Agreed. That said, often it's the smog test that reveals how not up to snuff a car really is (cats and O2 sensors get old, leaks happen, ignition gets weak, injectors gets clogged, sensors stop working, and on and on...).
All very helpful. Thanks. I think there is no upside to me registering it in CA. It may even go back to Nashville mid fall after Monterey due to garage space. TBD.
The big hitch I'm now running into is... you have to get a CA DL and register cars within 10 or so days of moving out here. But the earliest DMV appointment is... August 14th. Nice.
PS moved here for a great career opportunity I couldn't pass up. Been living in ATL for the past few years on a work assignment (it was a 6 month thing that turned into 4.5 years) so been a second since I've been in Nashville full time.
You can go to any DMV in California and get a license. I drive an hour to a DMV that I like. Each DMV is different for some reason in California. It’s not like in and out burger where they’re all the same. But you do need to have a registered car here to get a license no BS. If anything get your car pre smoked first to see if it will pass.
Location: Formerly the DPRK, now seeking political asylum in Oregon
CA law says that you need CA registration and CA driver's license "if you live, work or go to school here"
My $.02...
Keep your TN license and address (and insurance address... they'll ask for your insurance card!).
If pulled over, you're here on vacation. B*tch is getting pulled over by the same cop 6 months later. I'm sure there would be a fine involved.
Smog isn't always a huge hassle, but ALWAYS has that potential.
My $.02...
I think you will be fine with a bone-stock '86 as long as it is running well. The main issue is catalytic converter function, which might not be optimal in the case of a 32-year-old part. Make sure the engine/exhaust are hot, and ask the smog tech if a pre-test is possible so you don't get branded as a gross polluter.
Modified cars are more of a crapshoot. To this end, I made sure that my 951's engine compartment looks as factory as possible with the larger turbocharger and VEMS installation. All modifications were designed to be bolt-on and easily reversible if necessary. I am sometimes envious of those who live in states with no such requirements (my 951 would have a 1.8T or 07K swap if I lived elsewhere), but I love where I live so it is a sacrifice that I am OK with . . . .
I moved to the Bay Area in 1989 from Hawaii. I kept my Hawaii plates and drivers license Untill i donated both cars which was 10 years later and not once was I ever stopped for having an out of state plates. I did get stopped on I-5 for speeding but no mention of the out of state plates or drivers license. That’s maybe due to bein on the interstate. Two cars and both me and my wife had out of state drivers license.
i didn’t switch drivers license Untill late 90’s. I was in the military so I did have an excuse if I ever got stopped.
The CHP is particularly motivated to enforce CA registrations. Their funding is paid from it.
Keep your out of state license for sure, and remember "I'm only here on vacation".
And hope he doesn't see you again 6mo later.
