Clutch choice discussion: fork stress and 60-2 trigger
Good info, thanks guys. Interesting about the KEP Lite, first time hearing about it. I wonder if that torque figure could be increased with a slightly more aggressive disk. I'm not planning on making 500 ft-lbs or anything but I would rather get a clutch that I never have to worry about being a limiting factor.
I built the motor with Molnar rods, and have T&K head studs waiting to go in with a MS3Pro ECU, LR Super 61 turbo and full 3" exhaust. May sell the S61 and get a Voodoo turbo. So the motor itself should stand up to 400-450 ft-lbs in current form and I intend to be somewhere around there
Professional Hoon
More clamp load will equal to a heavier pedal but more torque holding capabilities.
A more aggressive clutch disc surface will also have more torque capabilities
Like i said, Spec uses an OEM Sachs PP. All their stages increase surface friction material on the clutches. So yes they will chatter or feel like they're more on/off. But you keep the same pedal feel and less stress on the fork.
Can anyone comment if this is legit? I trust Zims but this seems well below average price for a new Cup disk.
http://www.allzim.com/store/clutch-d...944-turbo.html
These are the cheapest sources I could find:
https://www.ebay.com/itm/Porsche-944-Sachs-Clutch-Disc-Sport-Spring-Hub-w-Organic-Lining-1861944433/111379865211?epid=235803727&hash=item19eec1de7b:g:jiMAAOSwaEhZOE2L
https://www.ebay.com/itm/Clutch-Disc-Sport-Spring-Hub-w-Organic-Lining-Higher-Friction-Porsche-944/152364633708?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
The KEP pressure plate is also cheaper direct from KEP themselves. (550 USD)
Found the disc for even cheaper:
https://www.rmeuropean.com/Products/...621-MFG38.aspx
Now to find the best deal on the release bearing. Seems like $180 is the cheapest.
Does anyone know the torque holding capabilities of the KEP1 + Cup disc combo? Reading conflicting information when I search. Patrick Motorsports says the KEP1 is good to 530 ft-lbs with a stock disc. This sounds really high? If that's true then it stands to reason that with the more aggressive liner on the Cup disc, 530 ft-lbs is the minimum it should take. Then I'm seeing people north of 400 fw tq being told they should get the KEP stage 2 and something like a 930 disc (on web forums like this one). Maybe I'm missing something, but it seems like the KEP stage 1 is fine for 99% of modified 951s. Curious to see at what point people are getting slip with KEP1s if at all.
If I were to bolt everything up and I couldn't get them to work I would be stuck with a bolt-on wheel. The only one worth a lick seems to be the Clewitt which is around the same cost as the 60-2 flywheel. I would love to prove the MS is capable of using stock sensors but I'm more focused on having a solid setup that I know will fire up with no worries. A solid signal through the whole rev range with no chance of timing drift. There will also be a Clewitt cam sensor installed for full sequential, so having 3 sensors for RPM inputs would be a lot. I know Audi did this with their Tri-tach system but it just seems like engineering wankery in 2018 when there are other options.
Cool, I'll let you know how the stock 951 triggers work with MS3. I have a cam sensor too... but that is for future winter projects. I'm starting with a distributor and stock sensors first. It's a big project already.
Decided to move forward with the TTV flywheel setup, a few others are getting them as well so we are doing a group buy. Currently around $400/person shipped from the UK. If anyone else wants one, there's a posting on the "Porsche 944 no spam" facebook page.
