Smoke on boost, Anybody experience this?
Sorry for the confusion, All my engine building is done in my friends shop that is all american..Anyhow it comes out to about 2.7L Valve Stems, Seats, and the valves themselves are all brand new and perfect.. I am sure of that.. Going to check out the Turbo then Re-Route AOS.
BTW The Can was vented to atmosphere and NOT back into the inlet of the turbo...
I could be wrong, but this is exactly what happened to me. But, both of mine were Garret hybrids with the single shaft seals. If the K-26 was properly done, that one should not smoke. What did the first turbo look like when you took it off? Oil in the turbine or the compressor side?
Not Really, I will have the Turbo checked out but there has been a new Development.... MY AOS had a Hole in it big enough to put a softball in... Holy Cow... It looks like there was a blowtorch inside it. I took the intake off and noticed "Plastic Slag" on the outside of it, looked a little deeper and Wow! Tried to take pics of it but they really did turn out crappy. When I get it removed I will post a pic... Everyone I have talked to says It does happen from time to time but nobody can tell me why. True it is 30 year old plastic.. but why the "blowtorch" effect? Hmmmmmmmm
Ok So I was taking the turbo off and noticed this.......
So a Rummage around my parts bin and a little "upgrade" so this will never happen again...
Yes all heat shields were in place, additionally the downpipe was wrapped with header wrap..... But I did find one of the Allen head screws that held the 3" Down pipe in place loosened up. the weird thing is that its pretty far away from where it melted the plastic. The whole 3" Down pipe is going away, with the stock turbo there is no need for it. I dont see any advantage in it, its just a pain in the *** to get in and out the flange is just ridiculous big.
I found an original down pipe in my pile of parts and I am modifying it to transition from the original size to 4" right after the starter...
I Just had the car Dyno-tuned, and I am positive timing/and backpressure is good, Its (was a 3" to 4" all the way back straight pipe) Im Pretty sure it was that stupid allen Screw coming loose. Im going to put a different oil feed line on the turbo with a built in filter from tims turbos. I will check the oil Return line.. So I am Curious,, When you remove the oil feed line from the top of the turbo I noticed that there was oil sitting there and not draining. Is that normal? OR should the oil drain down into the pan through the turbo?
Edit on my last comment. 2 days ago we replaced a turbo with a rebuilt unit on a skid steer. The oil wouldn't go down by spinning (or at least I got tired of trying). So... I guess different turbo bearings react differently. Most of my turbo replacement experience is on Cummins diesel engines & those ingest oil very easily.
Also, another thought is friction bearing vs roller bearing. I have no experience with roller bearing turbos, but have heard it will require a reduced amount of oil feed vs friction.
