Whats this noise
Old 05-18-2018, 09:39 PM
rond951
rond951's Avatar
Default Whats this noise
Just had installed Spec Stage 2+ clutch w/machined stock flywheel. I've put 600+ miles of break-in driving(careful). From the time I picked the vehicle I have a fair amount of drivetrain noise, it's a tinny sounding resonance( sort of like the sound of rattling heat shield) during deceleration most pronounced when slowing off throttle especially in 3rd and 2nd gear. You can hear it in 4th and 5th but it's not as noticeable. Seems to be coming from the transaxle? There also is a very slight vibration felt when accelerating up thru the gears. If I depress clutch or go to neutral with clutch out, noise/vibration completely go away. Any Thoughts? BTW 87 944 Turbo non LSD with 82K
Old 05-19-2018, 01:31 AM
Humboldtgrin
Humboldtgrin's Avatar
Torque tube bearings going out?
Old 05-19-2018, 02:03 AM
Mike Goebel
Mike Goebel's Avatar
If a stage II clutch includes a disk that is of the 930 type then the springs in the clutch just rattle like crazy under deceleration. It sounds scary but don't worry about it. It's just the springs that are semi unloaded and rattle quite a bit.
Mike G.
Old 05-19-2018, 06:13 PM
rond951
rond951's Avatar
Thanks, I hope that's all it is. It didn't make any noise/vibration with stock clutch
Thanks again,
Ron D.
Old 05-22-2018, 12:38 AM
fejjj
fejjj's Avatar
Thanks again,
Ron D.
This is normal.
Old 05-22-2018, 05:13 PM
rond951
rond951's Avatar
When you say this is normal, have you had/heard of this same issue?
Old 05-23-2018, 10:30 PM
Quickbeam
Quickbeam's Avatar
By machined do you mean lightened? I have a spec push clutch which has a lightened flywheel. I noticed a lot of gear rattle on deceleration around 2500 rpm.
Old 05-24-2018, 02:41 PM
rond951
rond951's Avatar
Not lightened, just machined true. I have the same rattle while decelerating especially noticeable at slow speeds as when around town 1-3.
Quick Reply: Whats this noise
