KLR Pin #2
KLR Pin #2
Hey guys, I’ve searched all over without luck. I’m in the process of installing a Lindsey Racing sensor harness and noticed that the factory wiring connects KLR pin #2 (timing valve (output)) to the idle control valve, but the new harness does not. I’ve noticed that sometimes the LR instructions use different wiring connections than the factory setup, but does anyone know the purpose of pin #2?
From a quick search I found a diagram of the dme/klr. It appears KLR #2 goes to the cycling valve. I find it odd the new harness doesn't have one. https://rennlist.com/forums/924-931-...tch-job-9.html
