Loss of power at high speed
What might cause a short loss of power when exceleration from 80-100? With the pedal to the ffloor the car just dropped power like I hit a brakes?!
I'm running stock chip. What else do you need from me? It feels like an over boost protection even though I have no clue what that would feel like. It happened once before when I really punched it. Throw out any suggestions on how I can debug.
thanks!!!
thanks!!!
You can check for error codes (ex Knock, Overboost...) by connecting an Led to the test port. Search for the procedure on how to do it. Overboost will give you a "3 - 2" code.
If you can boost in lower gears through the Rpm range, but not in 3rd or 4th, then it could be overboost.
Basically, the stock overboost kicks in when you the engine load (air flow / rpm) exceeds the programmed value (per rpm) , and it remains for a predetermined period.
In lower gears you go through the Rpm fast enough, you may not trigger overboost. In higher gears, you spend more time per Rpm which could be it.
If you removed the cat converter, raised boost, mismatch KLR chip (assuming cycling valve is used for boost control) or your AFM is off; any or all could cause it.
When you hit overboost, it's a fuel cut as in Rev limit. The engine will not die, but you cannot hit the gas. It remains for 30-60 sec, then it clears itself. Or if you cycle ignition.
That's probably it. Regardless, to get the most out of your turbo you need a performance chip, and turn up boost a bit. The other option is to get factory 951S DME and KLR chips, but may still risk overboost without the cat.
A manual boost controller is the easiest way to turn up boost. Keep in mind, the boost and engine management (chip) work as a system.
John & Forum,
I installed the Vitesse chip, boost/vacuum gauge & went from 2.5 to 3 bar fuel pressure regulator. The over boost issue is gone !
I do have a Lindsey racing boost enhancer hooked up and I'm not sure if it needs adjusting? removed? or left on? Any suggestions? How do I test? It was on the car when I got it.
thanks!
thanks!
