Running Tial with Cycling Valve
Hey folks,
I've got a full Fabspeed exhaust arriving in two or three weeks. In the meantime, I'm going to drop my cross-over, and re-seal/gasket and torque all of the exhaust components from the turbo charger to the headers and wastegate. Will probably also send the x-over to Lindsey to have them cut it so that future oil pan access is easier.
Question: I have an uninstalled Tial F38 (.5 bar spring - 7.25 psi) with adapters. Pulling/Installing this with the cross-over out is probably the ideal time. I would like to keep it in single port mode for now and run it off the cycling valve, just as the stock one is. Is there any issue with this? I am familiar with the design differences between tial and stock WRT to inlet and outlet, and where the vacuum lines go. Just need to know if I can swap out directly and not encounter anything unexpected with respect to boost. I have the A-tune.
Note: I am later going to dual-port with an EBC I already own. I want to keep it single port with no changes for now as I don't like changing too many things at once on these cars. Pulling the whole exhaust system and changing the wastegate is all I want to bite off in this round.
Jim, thanks for the quick reply. For my own understanding, why would this be different (in principle) from shimming a stock wastegate? Shimming effectively increases spring weight for the CV, correct?
Thanks, Scott
Thanks, Scott
No - the CV cycles/pulses, and as I understand it, the KLR code isn't really adaptive. It won't "learn" the new rate. It's just a set pulsewidth in a table, and is based on the assumption that the stock WG is there.
The *minimum* boost on the stock WG is 4psi. On your Tial, it's 7 (mine it's 10 - are you sure you're on a 7.25psi spring?) The stock spring in the stock WG will react at a certain rate (open/close, rate of open/rate of close, and response time between the CV opening/closing and boost rising/falling). The Tial will be different, and the CV control inside the KLR won't know that.
Got it - thanks for taking time for the explanation - much appreciated!
Yes, I have the .5bar/7.25lb spring - i want the ability to run it pretty close to stock once the ebc is in.
For your ebc (assuming you have it), where did you tie in for 12v switched? I have no more headroom on the radio power.
I've done exactly that; run a .5 bar spring using CV.
The CV/KLR doesn't know and doesn't care if you have a stiffer spring; you'll just have more boost, that's all. The amount of boost is generally the difference between the two springs, maybe a bit more. I think I saw 17-18 psi IIRC. Maybe that's more than what you want; not sure.
Turbo, ok that is interesting for sure. Did your car reliably hit whatever range (17-18, or any amount x) every time? I don't want any variability - want to hit x every time. A lower spring weight might get what I'm after.
I experimented with a custom tweaked KLR (built by a well known 951 tuner) a few years ago on my Tial and we never got any semblance of control out of it.
It's no different than using an aftermarket ebc, which is essentially an electronic tunable bleeder.
Basic spring pressure, bleed away a fixed amount of control pressure = "x" amount of boost over and above the spring.
I started my own thread on this yesterday. Just trying to make sense of this.
So I got the tile 38 wastegate installed. But as I said before the cyclic valve broke. So I just went with the manual boost controller which I plan on hooking up shortly. A couple questions
1)after hooking up the manual boost controller do I have to plug the J Boog hole? And if so what does everyone plug it with.
2) When I bought the car it had auto authority stage two chips on it. Which requires a banjo restriction on the intercooler pipe. Exactly where the vacuum hose goes for the wastegate. Do I need to source a stock banjo bolt? Or is the restricted one OK? Thanks.
edit, I’m just gonna source a new bolt for the intercooler pipe. A bolt that has a vacuum connection for the boost Controller. Would have thought LR would have supplied a bolt for that pipe.
1. Just find a bolt that fits in the j-boot hole and use a little hose clamp; 2. You could probably leave the smaller banjo bolt as is. To connect my new vacuum line—the tiny silicone ones from LR—I used a brass adapter from small to large and no problems. BTW that manual boost controller is funny: nothing, nothing, nothing then one little turn near the end and you're flying! Or... overboosting
