Very loose shift knob (video)
Old 06-03-2018, 11:06 PM
notny41
notny41's Avatar
Default Very loose shift **** (video)
Hi, I'm guessing I will probably need a new shift arm and maybe the bottom ball-joint bushing - wondering if anyone else's shifter is or has been like this?
Sorry for the robotic voice LOL - this video shows it in 4th gear, but it is this loose like this in every gear.
Old 06-04-2018, 06:16 AM
Chapman951
Chapman951's Avatar
Mine never had anywhere near that much play.
Old 06-04-2018, 09:38 AM
notny41
notny41's Avatar
Yeah, it's crazy. If you didn't know any better, you'd think the **** was in the neutral position...
Old 06-04-2018, 01:30 PM
bw993
bw993's Avatar
Had the same problem. You need to tighten the linkage at the back of the tranny that connects to the shifter.
Old 06-04-2018, 02:15 PM
notny41
notny41's Avatar
Hmmm ok, is that a difficult procedure or not too bad?
Old 06-04-2018, 11:57 PM
Brantley
Brantley's Avatar
Time for the Only944 short shifter -
https://www.only944.com/partscatalog/only/shortshifter/
Easy install and will be night and day different.
Old 06-05-2018, 03:31 AM
notny41
notny41's Avatar
I don't quite get the concept of the short-shifter. What does it do?
Old 06-05-2018, 09:38 AM
Tedro951
Tedro951's Avatar
The short shifter makes you very happy. I stalled both trans linkage pieces from only944, as well as bushings up front. I wish I'd done it 10 years ago..
Old 06-05-2018, 10:29 AM
notny41
notny41's Avatar
What is all involved in installing the short shift linkage(s)? What was your time to complete the job?
Old 06-05-2018, 10:58 AM
Chapman951
Chapman951's Avatar
I found this video. Hope it helps :-)
Old 06-05-2018, 12:42 PM
notny41
notny41's Avatar
Thanks for the vid! Wish it would have shown a little more about what is involved in putting in the short shift piece, but it was very entertaining nonetheless!
Old 06-05-2018, 10:39 PM
bradthebold
bradthebold's Avatar
The short shift part goes on the trans. Only944 has good instructions: https://www.only944.com/instructions...hifterinstall/
Old 06-06-2018, 01:21 AM
notny41
notny41's Avatar
Perfect - thanks brad!
Doesn't look all that daunting.
Old 06-06-2018, 06:32 AM
blade7
blade7's Avatar
I had to make a puller to remove the old linkage from the gearbox. As for the rod that goes over the top of the gearbox, it was a real PITA to fit.
Old 06-07-2018, 02:17 PM
Chris Prack
Chris Prack's Avatar
My money is on the shifter itself being worn out where the shift shaft attaches to the shifter. Instead of being cylindrical yours is most likely tapered on both ends. Pop the boot up and move it in gear like that again. You'll see it.
Quick Reply: Very loose shift knob (video)
