Cone air filter location
I'm looking at options to locate a cone air filter, either behind the wheel arch liner or behind the headlamp, is it likely a 240mm x 150mm filter will fit in either position without some cutting?
Rainman
dont know the typical kit pn but i got this ebay filter in there by cutting off the "arm bracket" on the back of the headlight bucket.
this was when I had a Rogue MAF setup. in this location, data logging showed that IAT got warm when idling/sitting still for extended periods but dropped to ambient almost immediately once in motion.
cone with 6" base + 4.5" top. actual filter area is 5" long (1" rubber clamp lip).
4.5" opening (i have a 4.5" OD x 3" ID bell-mouth velocity stack mounted inside the filter, connecting to the intake elbow)
Thanks for the info and pic , I'm a bit wary about cutting the headlamp bracket as it has the stop bolt. Does your headlamp shake in the up position ?
Hi , here's a picky of one of mine . You have to cut the headlight stop out to fit a decent size cone filter , on the other car I have a pipercross filter that fits in the hole in the chassis but is slightly smaller in size . Again the stop is missing as I am using D9 headlight covers.
How's the Vems install going ? I haven't got round to mine yet ,to busy fabricating pipework. Simon
My solution was to install the LR aluminum coolant tank. It’s designed to be shorter than stock to allow more room for the bigger cone. I’ve not done it but I also have seen and like the idea of blocking hot air in the engine bay from being able to enter the cone by building a bit of a wall after the cone to seal it off.
