Best Currently Avail Camber Plates?
So I bought some camber plates to replace my worn Stock top bearings, and their bottom surface is both too small to comfortably support the shock top hat, and also 1 1/4” lower than Stock, which reduces my travel to 1.5” which is basically on the bump stops and not good. What are the best ones to use that raise the top mount or at least keep it same height as Stock?
Thanks!
Thanks!
Is your car lower than stock?
Do you have coilovers fitted?
Most bottom mount camber plates will be fine on stock height cars and stock spring hats. If you have made changes it would be best to use top mounted camber plates to regain travel after lowering. I use the Ground Control version, which also has various options to accommodate different spring top configurations. They are well made and I’ve been happy with them.
FWIW - I bought a nice pair of OE strut mounts from LART for $99. Also if the rubber is good but bearing are dry you can carefully remove the bearing seals and regrease them.
The KW top mounts aren't the best out there. We had issues with the metal plate where the degrees would be inscribed, actually bent upwards under stress. Also it didn't allow for max travel and we ran into the bumpstops which eventuated in understeer in slow to medium speed corners. This was cleared up when we switched to the Racers Edge version which are built better and also raise the attachment point.
Here is a link to a Honda website that has a diagram of a front assembly.
http://www.meganracing.com/tech/faqs...ver%20assembly
