Hose ID help please :)
I know my NA cars pretty well but am still a toddler when it comes to the turbos. I'm trying to identify the rubber hose that runs from the RH side of the intercooler. It has a small split in it so I thought I should change it out.
Have I got the correct part here from the PET ... item #5 in the parts drawing doesn't look like the shape of the existing hose but I'm thinking that may be artistic license. Seems to be in the correct location. Part # 951-110-370-02?
Appreciate your help on this.
Assuming you are running the stock k26, you can buy a generic 45 degree 2.25" to 2" silicon elbow reducer and cut the 2.25" ID end short so that it matches the length of the stock hose. The offcut can be kept as a spare joiner for the intercooler inlet/outlets.
For example, this is the one I got:
http://www.ebay.com.au/itm/Aeroflow-...QAAOSw9JNZ5K07
You are correct the number 5 is the one in your pic and is just as you say not presented in the correct shape in the PET.
I would get the stock part from Porsche for a stock to mildly tuned car. If I know you correctly stock look is what you want
Also the stock part is a very good piece with very long sevice Life.
/Peder
/Peder
