Anyone installed LR TPS connector kit?
Here is the kit.. https://www.lindseyracing.com/LR/Por...-951-TPSC.html
Does this go all the way to the DME plug? I cut away the boot on the TPS connector and almost every wire has a break in the insulation.
Not sure if this is the cause of my car running bad. I do get a 4-1 Blinker code indicating bad tps or wiring...
That sucks that it doesn't go all the way to the DME.. I used their reference/speed sensor harness and it did go all the way to the DME plug. I know about the injector connectors. replaced those probably 7 years ago..
Why do you suspect the wiring itself is bad? You can always test it with a multimeter. Otherwise you can get a 6 pin junior powertimer Bosch connector for like $20, just crimp the pins to your harness. That's what I did when I built my standalone harness.
