Dry Sump
Dry Sump
Hi , I am looking at putting together a dry sump system on a new engine build . Just wanted to know what people did with the existing pump . The housing obviously remains but where is the block blanked of and how are people doing this . Pictures would be helpful.
Thank you for the response . Yes I have seen the Lindsey website but it has no mention of plugging original oil entry or I have failed to see it on their website .
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you use the plate that replaces the oil console then the path from the old oil galley is blocked off and the input on the plate goes directly to the main oil galley. just pull the gears out of the stock oil pump and you are good to go.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
yes, otherwise you would get an oil leak!
the drive gear does not drive anything but it is the point of contact for the crank seal.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Or just buy the Lindsey plate!
