Wheel spacers??
Registered User
Wheel spacers??
Has anyone put wheel spacers on the front of their car? I have just purchased two different brands of 15 mm. Neither will fit over the dust cap on the front hubs! Has anyone solved this problem? It's hard for me to believe that after 30 plus years no one makes a hub centric spacer that fits on the front of the 944/968. I have not tried H&R yet.
Registered User
Originally Posted by Fracture
Their 15mm don't look any different from the ones I have received. Have you tried them on the front?
not a 944 owner (see my sig)
I bought a set 7mm's hub centric / w/lugs for my 996 (wider is better)
haven't deployed them yet as I'm running 8.5 + 10.5 wide wheels
you may need an offset guide to help, I know very little about 944 set-ups
try this
http://www.willtheyfit.com
try this
Registered User
try this
try this
Registered User
post up some pics with approximations
your 944 may not be all original
Posting in here because not getting answers elsewhere and I think the front hubs are similar or same.
I put front spacers on mine. Had to machine the inner lip of the hub centric ring. Only works if spacers are wide enough, mine were 25 mm. This is what they looked like. My thread on pelicanparts.
http://forums.pelicanparts.com/porsc...aller-one.html
If you want to use 15 mm hubcentric spacers i think replacing the dust cover to something smaller is only route to go. I also tried cutting down the lip of the dust cover but it broke into two pieces.
