ROW - Bosch DME
05-28-2017, 06:25 PM
ROW - Bosch DME
Hi experts!
A DME question please. Does any body know if and how the
ROW DME will work on a US spec 944?
ROW - Rest of World, Non-USA vehicles (no catalytic converter, higher compression engine, etc).
05-29-2017, 01:51 PM
I thought all of the engine computers were the same, changing the coding plugs on the engine harness determined if it was USA/ROW
05-29-2017, 01:53 PM
Thank you.
what do you mean by coding plugs?
05-29-2017, 03:32 PM
There is a 2 prong plug on the DME harness. Porsche sells plugs that go into the plug to change to coding on the DME
06-01-2017, 01:41 PM
RainmanRennlist Member
No, the "coding plug" was just an AFR adjustment that on US models was hooked up to the barometric sensor to lean out AFR at high altitude.
06-01-2017, 01:49 PM
So,
the ROW DME will work?
06-01-2017, 05:16 PM
like i told you on FB...it should be fine.
06-05-2017, 09:34 PM
06-05-2017, 09:35 PM
Items 27, 28 and 30. The baro sensor is #20
06-15-2017, 05:11 PM
Former Vendor
Yeah that should be Plug and Play.
Usually ROW units do not have Oxygen Sensor capabilities and they tend to run a little faster also.
