944 & 944S Forum 1982-1991
944 wipers stuck
Old 04-26-2017, 02:40 PM
abueler
abueler's Avatar
Default 944 wipers stuck
Hello All, new to the forum here. My 1984 944 has a problem with the windshield wipers. They will come on but only sweep about half way up the windshield and then get stuck making a squealing noise. I can then move them by hand a little further and they will sweep the rest of the way and return back to the bottom. I have though about removing the motor and cleaning but wanted to see if anyone had any other ideas before I did this. Thank You
Old 04-27-2017, 01:21 AM
PaulD_944S2
PaulD_944S2's Avatar
Remove the motor, disassemble the gear box, then clean and lube, re-assemble. Carefully, small parts present.
NOTE: Carefully examine how the mechanism from the motor to the wiper arm axles is put together when you take it apart, otherwise your wipers may not arc correctly on the windshield.
Quick Reply: 944 wipers stuck
