944 & 944S Forum 1982-1991
Headlight motor delete
Old 03-17-2017, 11:52 AM
kings944
kings944's Avatar
Default Headlight motor delete
Hey guys I did a search and came up with a few threads on the topic but didn't see many alternatives. Looking to remove all my headlight motor/bars ect. wondering what solutions some have come up with?
I need to get the car inspected soon so I need a better or want a more permanent solution then zip ties.
I like Vt951 solution but haven't heard back from him to see if he has any more brackets or will have any more.
I do want to keep the flip up lights though, no gt mod.
TIA
Rob
Old 03-20-2017, 09:14 PM
kings944
kings944's Avatar
no suggestions guys?
Old 03-21-2017, 06:02 PM
V2Rocket
Rainman
V2Rocket's Avatar
https://rennlist.com/forums/924-931-...h4-lights.html
Old 03-24-2017, 03:14 PM
kings944
kings944's Avatar
Thanks, but that post is 7 years old not sure if any kit was ever made? Also I would like no electronics.
I really like Vt951s kit but I can't get a hold of him to find out if he makes them anymore, so I will see what else I can do I guess.
Old 03-27-2017, 04:57 PM
V2Rocket
Rainman
V2Rocket's Avatar
I was kind of thinking of making a DIY mechanical up/down system.
Modeled on the concept of how this "lid support" works, a slot for a bolt to slide through and you tighten it down in either up/down position (maybe a simple wing nut?)
Could make a bracket that attaches to the existing holes in the frame for the current headlight pivot brackets (black horseshoe shaped things)
Old 03-29-2017, 01:34 AM
kings944
kings944's Avatar
I like that! The wing nut would probably be strong enough to hold it.
Old 04-03-2017, 09:02 AM
87944turbo
87944turbo's Avatar
Alan just made another batch a couple months ago. I know b/c I just picked up a set! Took some time to get everything the way I wanted, but I can't imagine a simpler solution that is still functional.
If you need his contact info, just send me a PM.
Old 04-03-2017, 06:31 PM
kings944
kings944's Avatar
pm sent
Old 04-06-2017, 12:39 PM
jr10cross
jr10cross's Avatar
just a thought, you don't want to just fix them? I took a trip to the junkyard and got everything I needed after an accident. Check this out if you're interested:
Old 04-06-2017, 03:02 PM
kings944
kings944's Avatar
Before I got my car the PO was going to track the car and pulled the motor. So I don't have one
The car is also a little tiny bit tweaked in the frame rail that the motor bracket attaches too.
So I thought these brackets would be a bit easier to work with then getting the factory lights to work properly. Plus I would like the weight reduction/and to clean up the bay.
Old 04-07-2017, 10:41 AM
jr10cross
jr10cross's Avatar
Yeah I tweaked my frame going into a ditch at 65 mph, believe it or not I just needed the new side brackets to get it mounted properly again. I also had to do a bit of hammering to get the inside mount back in place . It was pretty easy.
Old 04-12-2017, 11:35 PM
kings944
kings944's Avatar
Well I ended up pulling a motor and bracket from another car. Bolted it right up and the headlights move up and down fine..
Would still love the brackets but nobody has gotten back to me in a month or so..
Quick Reply: Headlight motor delete
