my cheapest car is a Porsche
sup y'all, just picked up a 944 last week for $900. Its a 1985.5 944 non-turbo with 150k miles, clean title but pretty beat up.
PO claimed it was mechanically sound and everything was working fine before he got another car and sat this one for 4 months and now it wasn't starting and didn't know why. The cons are : dash cracked, no a/c, interior bits missing, and the terrible plastidip on the car.
PO didn't know what color the car was since it was plastidipped when he got it. He got it from a shop in NC that tracks 944s and told me how this was the owners toy so I'm hoping it was also maintained well.
i discovered the color of the car as soon as i got home.
it seems to me that it is a Crystal Green Metallic, which is cool because it seems like it's not that common. Only problem now is that i probably won't be able to save the OG paint because of the plastidip.
took the battery to go get checked at autozone and they told me that the battery was ruined, couldn't even recharge after 3 hours.
Got it a new battery and there it was! everything seemed to start working fine electrically which was one good sign!
i was able to get the car running shortly after with the help of some starter fluid.
i forgot to mention that it is tuned and has an exhaust so it was nice hearing it turn on for the first time.
https://www.youtube.com/watch?v=RMPm...ature=youtu.be
Good job saving another one! I bought my 85.5 as well for close to nothing. I had the same exact issue with being able to start it with starting fluid but not on its own. Check out my post if you continue having issues or need to laugh! I'm up and running now but a new DME is coming today because the board was actually fried from water damage.
https://rennlist.com/forums/944-and-...t-excited.html
congrats sir
congrats sir
Just for the record, as an advocate of plasti-dip as entertainment, it wasn't the dip that ruined the paint, sanded it or made a fender red. I've dipped several 2-4 year old cars and removed it with no signs it was ever there. I've also dipped several that looked like yours (with a coat of many sanded colors) just to have it all one color.
Nice score though :-)
Nice, looks like you got a good one for cheap! Engine looks clean and sounds like it runs pretty well too. Slap a coat of paint on her and she'll look like a million bucks. Well done, good to have you on Rennlist!
Nice job here resurrecting one from the scrap heap....always a noble thing to do. And I sure hate to be "that guy" but I did notice from the engine pic that your headlight motor relay (front passenger side area) is missing the rubber boot. This area will get wet so this may be one thing you want to take care of ASAP. And yes, I know from experience.
The piston inside the cylinder compresses the chamber through the movement of the crankshaft, making the cylinder optimal for the best explosion. You have in the cylinder gas, air, and compression. When the distributor sends the spark to the spark plug, an explosion inside the cylinder takes place. The explosion pushes down the piston which creates rotation in the crankshaft, thus eventually output power.
Starter fluid bypasses all components of the fuel system and spraying fuel directly into the air intake. Typically you remove the J boot, open the throttle body and spraying directly in the intake. This briefly mixes any air in the intake with fuel and that mix is inserted into the cylinders once the valves open when the engine is started. When you then attempt to start the vehicle, it will briefly run on the fuel air mix, but shut off when the fuel has been burned that was sprayed into the intake. Starter fluid is an affective way to confirm fuel delivery issues. Sometimes starter fluid can run an engine long enough to cause clogged injectors to free, thus fixing a potential fuel delivery problem.
I have a video of the fuel delivery system in a 944 if it helps.
