944 & 944S Forum 1982-1991
88' NA front spring popping
Old 02-19-2017, 10:00 PM
cleslie21
cleslie21's Avatar
Default 88' NA front spring popping
hi everyone,
after last weekend at Barber, my 944 has a popping noise in the front passenger wheel. I took a video(not sure how to load) but here is a picture. In the video, when you turn the steering wheel the spring rotates/jumps as you turn, and makes a cracking noise when turning left and right. I have heard it in the left wheel as well, but not as much. Any ideas? I'd like to go to another track weekend next weekend...
Old 02-19-2017, 11:49 PM
Dimi 944
Dimi 944's Avatar
It sounds as is the coils are binding. You can inspect and service the top hats which should have thrust bearings in them. Undo the 22mm bolt on top of the strut at full droop of the suspension. Remove the top hat and inspect the thrust bearings. They might be dirty and or/worn out. Ground Control and Lindsey Racing have replacements available. If you take measurements you can find replacements on the web as well.
Old 02-20-2017, 10:07 AM
cleslie21
cleslie21's Avatar
Thanks for the reply. Here is a video, I think I'll have to run it by my shop. I'll mention the thrust bearings.
Old 02-20-2017, 11:29 AM
Dimi 944
Dimi 944's Avatar
Yes, the thrust bearing is definitely binding. Also, as you can see it is not guiding the spring correctly that caused the spring to rub against the threaded collar and slowly destroying it.
Old 02-20-2017, 08:01 PM
cleslie21
cleslie21's Avatar
Hey Dimi
what do you think about this?
Old 02-20-2017, 08:04 PM
cleslie21
cleslie21's Avatar
Old 02-20-2017, 09:47 PM
Dimi 944
Dimi 944's Avatar
The hat will have a play but the bearing that is recessed in it from the top is the issue. It is what sits between the spring hat and bottom of the camber plate.
Old 02-20-2017, 10:21 PM
cleslie21
cleslie21's Avatar
Hey what is the fix?
Old 02-21-2017, 11:11 AM
AgLiftPilot
AgLiftPilot's Avatar
Are those ground control bottom mount camber plates? The coloring looks right for ground control. If they are, measure the spring diameter, then call them to see what they have to say. They should be able to supply you with new, correct bushings/bearings for the spring top hat.
Old 02-21-2017, 03:00 PM
Dimi 944
Dimi 944's Avatar
Replace the thrust bearings.
Call Ground Control or Lindset Racing as both carry the part.
Old 02-21-2017, 10:33 PM
cleslie21
cleslie21's Avatar
check it out, I called ground control. They said to apply grease to the bearing and the rod and hat after cleaning. No sound!
Old 02-21-2017, 10:46 PM
Dimi 944
Dimi 944's Avatar
Glad to hear. Mine was full of sand and the bearing were shot.
Old 02-22-2017, 10:54 AM
cleslie21
cleslie21's Avatar
You were spot on Dimi, thanks again! It made more sense when Ground Control asked if I had raced in the rain. I went to Roebling in savannah about a month ago and we ran in the pouring rain for almost 2 days straight. It must have washed all the grease out and added some sand cheers
Quick Reply: 88' NA front spring popping
