944 & 944S Forum 1982-1991
944S Cyl Head Pressure reducing Valve
Old 10-16-2016, 04:11 PM
chefyong
chefyong's Avatar
Default 944S Cyl Head Pressure reducing Valve
Hi,
I own a 944S and plan to replace the Cylinder Head Pressure Reducing Valve (944 107 139 00). I found out that it cost $500+.
Does anyone know where I could just get the 2 O-rings or Oil seal of the valve?
Attached picture below.
Thanks to all.
Old 10-16-2016, 09:31 PM
V2Rocket
Rainman
V2Rocket's Avatar
o rings are standardized...pull them off and find a hydraulic supply store near you, they should have a large selection of o rings and find something that matches.
Old 10-17-2016, 10:54 AM
ramius665
ramius665's Avatar
Just checked the PET and the o-rings are not listed separately. I'd follow Spencer's advice to source replacements.
Old 10-18-2016, 06:04 PM
KevinGross
KevinGross's Avatar
Get BUNA-N 70 metric o-rings from ORingsAndMore or The ORing Store . I order from them frequently for transmissions for which Porsche no longer offers seal kits. They're the right part, and wicked inexpensive.
Kevin
Catellus Engineering, Inc.
catelluseng@gmail.com
Jay Wellwood (12-25-2023)
Old 10-20-2016, 11:03 AM
chefyong
chefyong's Avatar
Thanks for all the help. I will try to reach them tomorrow.
Old 10-26-2016, 04:17 PM
michaelmount123
michaelmount123's Avatar
If memory serves me, you want #010 and #011 for replacements.
MM
Old 11-08-2016, 02:59 PM
Jay W
Jay W's Avatar
The pressure valve on mine was clogged up with debris and kept oil from getting to the top of the head after work done to replace the valves. Make sure to clean it out while you have it out. I cleaned mine and changed the o-rings rather than buy a new one
Old 11-11-2016, 07:39 AM
CVR_Rally
CVR_Rally's Avatar
Yes there is little to go wrong with the valve other than clogging and o-rings. I actually put mine in a sonic cleaner then used compressed air to check operation. No need to buy a new one unless there is obvious damage.
Here is what mine looked like after cleaning.
Old 02-13-2023, 02:55 PM
Bryant1234
Bryant1234's Avatar
This is a long shot but how did you use the compressed air to test to see if it was working properly?
Old 02-14-2023, 04:38 PM
michaelmount123
Blow into a lower hole with an air nozzle while thumb and forefinger cover two of the (lower) holes. You should see the piston move up and at least partially uncover the upper holes. Watch the piston move up and down a few times as put the nozzle to the hole and remove it. If the piston doesn't stick, you're ready to reinstall it.
The following 2 users liked this post by michaelmount123:
931guru (02-15-2023), Tiger03447 (03-25-2023)
Quick Reply: 944S Cyl Head Pressure reducing Valve
