944 & 944S Forum 1982-1991
89 944 headlights down but not up
Old 10-10-2016, 01:22 PM
demo57
demo57's Avatar
Default 89 944 headlights down but not up
new 89 owner. headlight function acting up very recently (since owned).
headlights will not open w/switch. when opened manually to full position (with switch in open position) the switch will close them.
headlights work (high and low/parking etc.)
fuses test good. relay shows proper resistance.
motor bad? switch?
interested if anyone has a similar problem and suggestion/advice for me.
thanks
Old 10-10-2016, 05:19 PM
mel_t_vin
mel_t_vin's Avatar
Could be the head light switch [contacts]...but probably the motor-mounted relay.
Old 10-12-2016, 03:01 PM
demo57
demo57's Avatar
allen
good deal. relay i thought tested out ok was BAD!
Old 10-12-2016, 11:28 PM
mel_t_vin
mel_t_vin's Avatar
That's the second one this week. Happy motoring...
Old 10-13-2016, 07:34 AM
Schmooey
Schmooey's Avatar
I just had a headlight relay issue as well. The lights would not rise up when the switch was pressed, but when I turned it back off, they both popped up and winked briefly and the went back down. I pulled the relay, shook it a bit and put it back and it now works correctly. Hope the new relay arrives before this happens again!
Quick Reply: 89 944 headlights down but not up
