Need help indentifying hose
so I want to know the part number or whatever it is so that I can purchase a new radiator hose. I'm new to car parts so bare with me. The part in talking about is the one that has tape on it
Also for further reference how could I find this out myself. Also does anyone know if this ho is pressurized and whether or not I could put it on myself.
Rainman
Go here:
http://www.pelicanparts.com/catalog/..._pg2.htm#item6
And look for part number 944-106-245-01-M253
Max pressure should be about 13-15psi depending on which radiator cap you have. You can put it on yourself but be prepared to collect leaking coolant/refill the water that came out.
This should come in handy for you in the future:
http://www.porsche.com/all/media/pdf...85_KATALOG.pdf
It can be a bit tough to navigate to begin with, but you can find part numbers for almost anything in the car in that pdf, and it's actually a legal copy straight from Porsche!
Go here:
http://www.clarks-garage.com/ Clark's Garage is a great site as well. It's got some helpful tips and write ups, I use it pretty often. Also, if you go to the "Garage Shop Manual" link, then scroll all the way down to the bottom, under Miscellaneous click on the "Parts-1982 to 1985" and its the parts book for your car. I have the later series parts book saved to my computer, I use it all the time. Also, you can definitely handle replacing the hose, you shouldn't have any problem. Good luck man!
