Weird tick
Timing belt tensioner pads worn? Broken cam teeth? Have you taken off the valve cover an checked to pad condition? I recommend catching up on the routine maintenance and see if the noise goes away. Hand on is the only way your going to find out. So get to it and tell us what you found.
Do you mean the chain pads? and by broken cam teeth do you mean the roller or the actual cam? I have a complete timing kit coming this week belts, seals, water pump, etc. I'll keep this updated to what i find.
