megasquirt 3.0 s2 coil on plug ?
Anyone done it yet? I'm curious what coils you used and if you used the 60-2 Flywheel trigger or a front 36-1 wheel.
Pete
Pete
Freedom Enthusiast
I'm working on it but I have a long way to go before it is finished. I have the 2.0 VAG coils and I plan to use the 60-2 flywheel trigger.
Freedom Enthusiast
I am not thrilled with how they fit. With the contours of the cam cover and the length/height of the coils, there is no perfect way to make them fit.
I haven't decided which direction I want them to go yet but this is one idea.
Freedom Enthusiast
That's what I did, works great, one word of caution, the power line for original coil is a resistance line, has 1k ohm built into it. Just FYI, caused me some problems.
Freedom Enthusiast
All the info you could ever want...
https://rennlist.com/forums/924-931-...our-944-a.html
https://rennlist.com/forums/924-931-...-and-more.html
My solution, re. the fit is to use large rubber tap washers to make them fit snug, so no debris can get down there, I've ordered some large o rings to give them a go as well
The rail is now painted black (looks more Porsche to me)
