Are Cabrio interio door panels different than standard S2/Turbo panels?
Question that I can't seem to find an answer for. Are 944 S2 cabriolet interior door panels interchangeable with those from a hardtop S2 and/or 944 turbo?
not absolute, but they prob have diff part numbers. the cab has a 2 piece window, and the interior door panel has a slight cutout for it where the coupe has a solid side window. im assuming the coupe doesnt have this cutout, but i know for a fact the cab does.
Yes, but...
I believe the cutout culture speaks of is completely contained within the trim piece on the top of the door - the inside window scraper. I'll see if I can find a photo to show you.
Pet shows one door card for both models
http://www.porsche.com/all/media/pdf...91_KATALOG.pdf
Look at page 276. There is a different trim piece to accommodate the stationary window on the cab, but otherwise, the door card is the same between both the coupe and cab.
I've seen a close up photo within just the past few days showing the door and trim but can't locate it right now.
i had a good look at my cab panel today. the above is correct, the cutout is in the inside window scraper (rubber trim)
