nostart cranks
nostart cranks
hi just bought this black on black 1987 944
i was driving around today and stoped too get gas , after getting gas the car would not start , checked all fuses and relay connections no start please any help on what to do next thanks mike
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Mike,
First thing to do is replace or at least check the DME/Fuel pump relay. VERY well known problem. You will find the relay number under the fuse panel lid. No start after seemingly normal running means almost always points to lack of fuel supply. Can you hear fuel pump running. Should run with ignition on. Do not need to be in start or run,
Ciao,
Adrian
911C4
Ciao,
Adrian
911C4
