Central locking problem
The central locking system on my S2 sometimes chatters away to itself on bumpy roads: if you push the doorbutton down slightly, you can feel that it's constantly trying to unlock the doors, even though they're already unlocked. In all other respects it works normally. Anyone come across this before, & is there an easy fix? Or is it worth worrying about at all?
Sounds like either a loose connection or a cable earthing.
try the cables coming from the door to the car , see if anything is fraying.
Also you could try resetting the alarm/central locking.
incase it's glitching.
remove the battery for about 10 seconds
oh lift up the fuse lid and listen to see if any relays are chattereing, if so pull it and replace it , might just be a dodgy contact
hope this helps
Adrian
hope this helps
Adrian
