Motor Mount Replacement?
When going in reverse, my car sorta jumps. ALso, the exhaust has cracked At the downpipe, Right after the cat, and right where the pipe goes into the can. i am wondering if all the vibration could be coming from the motormounts,
Matt
'83 944
Matt
'83 944
If your engine vibrates at idle the motor mounts are probably toast. My ace mechanic friend and I changed the mounts on my 83. The old mounts were so worn that my engine actually sat over 1" higher with the new mounts!
when the car is off and i push in the clutch, the engine accually moves ...i think the mounts are horribly bad, and i think i just got used to the vibration
