85-1/2 tripometer
85-1/2 tripometer
When I push the reset button the volt meter drops 2 volts and trip does nothing. Any suggestions before I blow some bucks on a new spedo to fix it.
David M.
hpandsd@ev1.net
p.s. Still parting out that 84 944 if anyone need parts.
David M.
hpandsd@ev1.net
Didn't see anyother posts, so here it goes. Sounds like a you got a sticking solenoid that resets the trip meter or a short in the wires. Check the wiring. If you have some time you probably can pull the speedometer out and clean the solenoid. Not positive but its worth a shot, and will give you a chance to do some cleaning. Goodluck
David,
I’d recommend having your speedometer repaired as apposed to buying a new/rebuilt one with an unknown history.
I was refereed to Specmo, a company in Michigan who did my buddy’s ’87 944S speed. I removed the speedometer and shipped it off to them. They repaired it and had it back in my hands in about seven-business days. It looked as good as new and cost was $125.00 + tax. Specmo’s address is listed below.
Specmo Enterprises
29624 Woodward Ave.
Royal Oak, Mi 48073
248-399-5645
Specmo Enterprises
29624 Woodward Ave.
Royal Oak, Mi 48073
248-399-5645
Originally posted by David M.:
<STRONG>When I push the reset button the volt meter drops 2 volts and trip does nothing. Any suggestions before I blow some bucks on a new spedo to fix it.
David M.
hpandsd@ev1.net
p.s. Still parting out that 84 944 if anyone need parts.</STRONG>
David M.
hpandsd@ev1.net
