944 & 944S Forum 1982-1991
Cutting Out
Old 01-30-2002, 11:46 PM
MDurham
MDurham's Avatar
Post Cutting Out
Thanks in advance for all your help. This is a great site. My 86 951 is cutting out after warming up to normal op temp around 2200 rpm she just quits. After maybe 5 seconds starts up again. It will idle forever with no problem. Changed plugs,ign wires,coil,throttle position switch, that fixed cold idle but still same problem. Last test run I wiggled the dme box and I think that fixed it temporarly. If it is the dme box is there a trick to open up those little metal tabs on the cover.
Thanks Mark
Quick Reply: Cutting Out
