Sunroof intermittantly won't open
Check the micro switch over the rear view mirror. The front center of the sunroof pushes on the switch to make contact as it opens it releases the switch to stop the sunroof. If the switch goes bad or is out of adjustment the sunroof will not work.
Very interesting. I had the exact same problem on my '87 944 n/a. It was suggested that I had a grounding problem. Before I could figure out the sunroof, my dash lights quit--and again it was suggested that it was a grounding problem. I finally got some help from a fellow owner who pointed out that there are grounding points inside the car under the dash essentially below where the fuse/relay box is (there were 4 grounding bolts/wires there. I got them all cleaned up and be damned if dash lights didn't come back to life but now car won't start. So, I've either knocked something loose or roasted something fooling around with ground wires. I'm still chasing this and running out of summer while my car sits.
I've read a lot about microswitches too but you might check for grounds as well. If anybody has an idea about my starting problem I'm all ears.
There is a great description of the Sunroof operation here http://boerger.golden-tech.com/favorite.htm
Hope it helps
Bill
Hope it helps
Bill
