Squealing bearing in the torque tube
DOes anyone know how much it would cost to replace these bearings in the torque which connects the engine to the transaxle..The noise is getting really annoying..
I think changing the Pilot bearing is going to be expensive cos you can't just slide the torque tube out like you can on a 68
the part's are cheap, labour and time wont be.
while your at it get them to check the oil seal on the gearbox, while it's out you might as well change that if it's necessary
It's an 8 or 10 hour job, I've done 2 of them. The bearing/hub assy is no longer available from Porsche, but the actual bearings in the hubs are a common part available from any bearing supply, I think the parts are $40.00 - $60.00.
You can re-use everything that Porsche added to the common bearing if you're careful. We had to make special tools to do the job, nobody sells a 5 foot long bearing puller that fits through a 1" hole.
So, the whole job, If you can find a shop that can do it, should be $600.00 - $1,000.00.
Originally posted by ast2000:
<STRONG>It might be cheaper, as well as much easier to find a used unit somewhere. BTW- I haven't seen any on Ebay.</STRONG>
Damn i love my 944 but hate the damn noise, hopefully i could find a shop in the ny area or unfortunatly i will have to let her go..
Originally posted by Steve, 914 guy:
<STRONG>It's an 8 or 10 hour job, I've done 2 of them. The bearing/hub assy is no longer available from Porsche, but the actual bearings in the hubs are a common part available from any bearing supply, I think the parts are $40.00 - $60.00.
So, the whole job, If you can find a shop that can do it, should be $600.00 - $1,000.00.</STRONG>
my torque tube bearing is squealing too, what can happen if i wait a little while to replace it? i'd like to wait for snow, since my car will be stored any ways.
also, In the classifieds there is a listing for "various parts" i think, they have used ones for $350
8th Gear
It is possible to install grease fittings above the torque tube bushings to stop the squeak. This was done on my 86 951 and works great, I'm going to do this on my early 85 also. null racnguy7@aol.com
