FS: 1987 Porsche 944 Black $4500
I have a black 1987 Porsche 944 with black leather interior and 200k miles for sale. I have a thick stack of maintenance records/window sticker since the car was brand new. The car runs great and is very reliable. I have had it for 2.5 years and I am the third owner. I bought the car with 183k on it. Work done since I've owned the car:
- Timing belt, balance belt, and rollers
- All 4 wheels bearings
- Voltage regulator
- Air filter
- Distributor cap and rotor
- Spark plugs
- Spark plug wires
- Fuel filter
- Fuel lines
- Coolant flush
- Transaxle fluid (Redline)
- Heater valve hose
- Motor mounts
- Brake fluid reservoir seal
- Brake fluid flush
Upgrades include:
- Koni Yellow shocks (adjustable compression)
- Ground control coil over sleeves and 250 lbs springs in the front
- 27mm torsion bars in the rear
- Neatrix spring plate bushings
- Weltmeister rear sway bar
- Rear wiper delete
- Pioneer F310BT navigation unit
- Alpine speakers
- Porsche Boxster 17" wheels
- H4 headlight bulb conversion
- H&R extended wheel studs with 7 mm spacers in the front and 15mm spacers in the rear
- Turbo rear diffuser
- Turbo side skirts
- Carbon alarm with key-less entry and power door locks
- LED cluster bulbs
Lower radiator hose was replaced at 180k. Clutch, fuel pump, and heater valve was done at 130k. I have a pre-purchase inspection sheet done by CT Automotive at 183k miles. The car last passed smog on March 26 2011. Registration for the year was just paid. Just had the car professionally detailed for the sale. Comes with factory air pump, spare tire, sunroof bag, and car cover.
There is a crack in the lower passenger side of the windshield and a cigarette lighter burn on dash from previous owner.
Asking $4,500 obo. I am located in Santa Clara, CA
email me at vexcraigs@gmail.com. I do not check PMs often.
- Voltage regulator
- Air filter
- Spark plugs
- Spark plug wires
- Fuel filter
- Fuel lines
- Coolant flush
- Heater valve hose
- Motor mounts
- Brake fluid flush
Upgrades include:
- Rear wiper delete
- Alpine speakers
- Turbo side skirts
- LED cluster bulbs
